Solar panels
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
Not true!
In this article, MaineSail shows how a 12W panel brought a 220Ah bank of batteries to 15 volts. http://www.pbase.com/mainecruising/do_i_need_a_controller
Charge controllers are probably less expensive than replacing batteries all the time.
Yeah... I guess if you have it hooked up ALL THE TIME and don't have any load. When I used my 45W panel, I just hooked it to the battery when I was using it. I just put it where the sun was, adjusting as the day went on. When not in use, I disconnected it and put it away. If you use it this way, you don't need a controller.
druid
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
@Sailm8 Do you have the specs, or a link to the product?
I think this was the company. It's been a while since I bought them: https://www.amazon.com/HQST-Monocry...72775485&sr=8-2&keywords=flexible+solar+panel
They are like seconds and you need to check them out to make sure they put out up to specs but mine did right out of the box. Used Amazon Primes so I could sent them back if they were out of spec. Bought a vectron (sp) MPPT controller to go with them. I mounted them on the bimini with zip ties. Currently holding up just fine to Tropical Storm Hermine.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
That far north you might want to tilt those panels to maximize any sun. I have a 50w panel on my backhoe with a little controller to protect from an overcharge. Works slick even with 6" of snow on top.
All U Get
Aug 17, 2013
1,309
Pearson P30 202 Ottawa
for now I've added a second battery, simple enough project, now I can focus on where I can put the solar panel
RussC
Sep 11, 2015
1,732
Merit 22- Oregon lakes
Mounted mine off the rear by using a curved 1" aluminum tube clamped to the upright. gets it totally out of the cockpit and out of the way. controller is in the cabin. takes minor fabrication work, but all easy stuff. The curved tube was stolen from a dead sears weedwhacker ;) .
You don't plan on installing all three panels do you? what do you plan to run with them? My 40W has proven to be more than enough for multi day trips powering stereo cd player, Garmin sonar, lights, etc.
Likes: SOCAL C50
Mar 1, 2012
2,182
View attachment 127758 View attachment 127759
Lived aboard and cruised full time for 2 1/2 years using a single 32 watt panel,, and a single battery. In that time,, had to go in and plug in a battery charger twice, due to prolonged very cloudy weather. Charged laptops and phones with no trouble.
Of course, I am VERY frugal with my electricity
Feb 11, 2012
271
C&C Mega 30 Long Point, Lake Erie
Three 7 watt solar panels...2 aft (for 2 house 27N deep cycles)....& 1 forward (with a smaller 24 for the bow thruster)
Both set ups have charge controllers, and never need charging otherwise
Apr 4, 2016
201
Newport 28 Richardson Marina
On My Neptune 24 I mounted a mast on the stern opposite the outboard motor. The 55 watt panel was 6'6" off the deck when horizontal so it was not a head knocker and it also protected it from flying beer bottles on tacks. When docked or anchored I would tilt it to the sun.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Your boat has a BACKHOE? That's awesome! Bet that comes in handy for digging clams! I wanted a davit (crane type) on the main deck behind the boom, but my builder said we would probably have to reinforce the steel deck...
Dec 27, 2011
279
Oday 272 Pensacola
I have a 25W panel, controller, 2 type 31 Duracell deep cycle batteries. Started using battery 1 to start westerbeke diesel one time, battery 2 next time. Went out yesterday & tried using battery 1. Wouldn't start. Changed to both battery & started fine. Batts are 1 yr old. What should I have controller set on for trickle charge? Was prev set for 13.7. I bumped it up to 14.2. Has been 2 weeks since motor started. No drain on batts, only use to start motor and occasional depth gauge. Battery selector always turned to off before leaving boat.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Much misinformation on this site relating to solar panels. If controllers are needed on such small panels as is stated here we would be using controllers on 115AC trickle chargers! Chief
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
MaineSail has seen small panels that supposedly did not need a controller bring a battery beyond charged and ruin it. Admittedly, this happened over the course of a whole winter or something, but still...
11,759
Most "trickle chargers" have built in regulation circuitry. For constant current "trickle chargers", of which there are very, very few today, most battery makers will void warranty if you use them. They all recommend CC-CV charging.
I have seen numerous banks destroyed by unregulated solar, even with very small panels compared to bank size...
Nov 26, 2012
2,315
Cheap trickle chargers still are not regulated, and many people use them with no problem. Their "regulation" is the DC potential they produce which is barely above or at full battery DC charge. The concepts regarding small solar panels are much misconstrued with regard to use of regulators! If the batteries are fully charged the voltage difference due to load effect between a small panel and bank is so small that there is minimal current, cool batteries. The best approach to this is to not leave them unattended for extended times no matter what system you use. MS, your advice to fully charge and leave them off the circuit in the winter or when not attended is best and is what I do for winter. Chief
Nov 26, 2012
2,315
Brian S: Electronic theory indicates that the small panels could not cause such problems and so likely the batteries, wiring, etc. were questionable, or some other reason if the batteries failed . My education tells me, if current level does not EVER exceed 2% or less of the total battery ampere hour rating the wattage conversion to heat is insufficient to cause such malfunctions. Of course the solar industry would like for everyone to think they need a controller and sell them one. I do think greater caution is in order for boats. Chief
11,759
Chief,
The terms "Trickle" and "Maintainer" have become abused and diluted definitions. Historically "trickle" meant a trickle of constant-current with no voltage regulation. Charger makers have smartened up a LOT over the years, probably driven by lawyers, and tickle charging is almost non-existent today except for perhaps a few bottom feeding Chinese products.
There is not a battery maker out there who does not require a CC-CV (constant current to constant voltage) charge regimen
I don't know how "cheap" you are going but even the Harbor Freight "trickle chargers" or "maintenance chargers" are float voltage regulated.
The Battery Tender is float voltage regulated.
The BatteryMINDer is float voltage regulated.
The Schumacher "trickle charger" is float voltage regulated.
The CTEK's are float voltage regulated
The Black & Decker trickle/maintainers are float voltage regulated.
The NOCO is voltage regulated On/Off (pulse) charging
Etc. etc.
Even battery manufacturers such as Lifeline weigh in on "constant-current "trickle" charging:
"Trickle Charging
Method of charging in which the battery is either continuously or intermittently connected to a constant current charging source to maintain the battery in a fully charged condition. Not recommended for use with Lifeline® AGM batteries."
FWIW this is a 400Ah bank that requires just 00.1A to not exceed 14.4V once the battery is "fully charged". This battery should be "floating" at 13.5V not being held at a CV of 14.4V. Even a diminutive 1.0A constant current trickle charger will easily push this bank beyond 15.0V..
11,759
Chief,
Sorry but you are incorrect on this.. Do your self a favor and please watch the videos and read the below article.
2% of Ah capacity in constant current will FRY your batteries. This 2% as "full" BS started with Ah counter manufacturers needing a % of Ah capacity "figure" to re-set an Ah counter to 100% SOC. It does NOT mean the battery can continually continue taking 2% of Ah capacity. Most batteries are not full, meaning they will not deliver 100% of Ah capacity, until the current has fallen to 0.3 -0.7% of Ah capacity. If you hold constant voltage at absorption, beyond this point, and do not drop to a float CV, you are now over charging your batteries. If you hold constant-current, with no voltage regulation, you will destroy them even faster.
Do I Need a Solar Controller (LINK)
