Disclaimer: I would never suggest and I am not suggesting the use of an iPad as your primary (only) means of electronic navigation.
I know a lot of boaters are keen on using their iPad's for navigation or planning, and I do too, as a secondary or tertiary device, but the issues with iPad's in the marine market are well known, especially in regards to the screen.
Last week I had an opportunity to run into Ben Ellison and get on-board his boat Gizmo for a bit of consulting (charging system work), and some fun playing with all the Gizmo's on-board. Ben is the owner of Panbo and is perhaps the industries leading writer of all things marine electronics.
While on-board I noticed Ben had a new iPad Pro 9.7". I had heard rumors about the new screen but finding legit reviews & comparisons were scant. I ran back over to our boat and grabbed my own iPad Air 2 for some comparisons.
Both Ben and I had pretty much all the good navigation apps loaded onto our iPads such as iNavX, Navionics, iSailor, Garmin Blue Chart etc. etc.. so comparisons in speed, brightness and glare were easy.
Screen:
The new iPad Pro does have an impressive screen especially compared to the iPad Air 2. Very, very crisp, considerably brighter in broad daylight and much less screen glare. The reductions in screen glare are what really stuck out.. Compared to my iPad Air 2 the new screen is really a leaps & bounds improvement but mostly due to the anti-glare coating not necessarily brightness..
Compared to an actual marine plotter it was still only marginal and Ben had four 16" +/- MFD's to play with on the bridge a Raymarine, Simrad, Furuno and a Garmin... The iPad Pro still has a ways to go to compete with a true marine MFD in both glare and daylight visibility. All the MFD's were easily visible in direct sun and even the iPad Pro struggled to compete. The iPad Air 2 is a really quite a joke in comparison for daylight vis.
Speed:
The iPad Pro is considerably faster at loading, panning and zooming charts than the iPad Air 2. It redraws nearly as fast as your fingers move. A definite upgrade over the iPad Air 2 and in some cases as fast or faster than some of the big MFD's.
Drawbacks:
The typical drawbacks with iPad's still apply such as pricing, overheating (mine over heated twice in the last 12 days), lack of water-proof charging, poor battery life and the fact that there is currently no good waterproof case for the iPad Pro 9.7". LifeProof can't even tell me an expected launch date for their NÜÜD or FRĒ cases for the Pro 9.7".
Pricing for the new iPad Pro 9.7" is also quite insane especially when you consider that you will want a cellular enabled iPad Pro in order to get an internal GPS. The least expensive iPad Pro with internal GPS is $729.00.
Verdict: I'll wait until the next model to move up to the Pro and until a waterproof case comes out to fit it...
Inside Visibility - Both iPad's On Max Brightness (Pro Left)
Morning Sun: (Pro on Left)
Screen Glare:
Screen:
Speed:
Drawbacks:
Screen Glare:
