Anyone have a suggestion on how best to remove excess caulking from fiberglass?
Not really too tricky, but yeah, flat and slow. What kind of caulk, FlimFlamll?This is tricky. You need to keep any sharp tool flat so as not to gouge the Gel Coat. Work slowly.
SIS 440 Teak Caulking. They had no instructions for removal...Not really too tricky, but yeah, flat and slow. What kind of caulk, FlimFlamll?
Hopefully there won't be a next time... I did mask the other bench but did not remove the tape prior to the caulk setting up so still suffer from the same issue on that side but not as bad. Thanks,If you use a caulk remover it will wick along all the edges and probably into the teak and weaken the bond on the whole project. The stuff is designed to wick. Don't do it.
Slow work with mechanical means. And mask next time. Also, the masking tape needs to come off as soon as you are finished, before the caulk skins over. This is different from painting.
This is the 3M caulk remover. http://amzn.to/2bZ1G8I
It works well, let it sit on the caulk for a while then use a plastic scraper. It may take several applications.
Take a sharp razor knife and cut the caulk where you want it to end. This will help prevent pulling the caulk away from the teak. Use a straightedge to get a clean cut. Once you make the cut it may be possible to gently peel the old caulk away from the gelcoat. Pull parallel to the deck, not straight up.
If you used blue tape, the second side should be easier. Cut the caulk with a razor knife and straightedge and then peal the tape back parallel to the deck.Hopefully there won't be a next time... I did mask the other bench but did not remove the tape prior to the caulk setting up so still suffer from the same issue on that side but not as bad. Thanks,
The stuff is pretty thick, about the thickness of hand lotion. I suppose it is possible, but I've not had that experience. If you slice the caulking first and work from the outside towards the teak, you can mitigate any bleeding problems.What about thinwaters comment about the stuff wicking into the caulking I don't want to remove?
thanks,
Thanks!The stuff is pretty thick, about the thickness of hand lotion. I suppose it is possible, but I've not had that experience. If you slice the caulking first and work from the outside towards the teak, you can mitigate any bleeding problems.
(Edit) The caulk remover loosens the bond, it doesn't really dissolve the caulk.
