Bbq cleaning
Aug 17, 2013
1,343
Pearson P30 202 Ottawa
ok everyone, time to spill the beans, what do you all use to deep clean a stainless Bbq?
mine is in dire need of a cleaning, but I'm not sure how to proceed
as usual, thanks in advance
Hunter 34 Alameda CA
Isn't that where the flavor comes from?
Otherwise after scraping, a Brillo pad with soap helps a lot. Sometimes followed by spray on EZ Off oven cleaner.
Feb 21, 2008
421
Hunter 33 Metedeconk River
Be careful using those cheap brushes with the metal bristles, I hear some may fall out and contaminate the food. Burn the stuff off and scrape it.
Likes: Benny17441
"Bar Keepers Friend" in powder or now soft squeeze. Scrape the big pieces off first. Then go to town with a kitchen sponge. Really burnt goo, put a little "Bar Keep" on and dampen. Let soak then sponge/rinse off.
ALL SHINY AGAIN
Beneteau 323 Annapolis MD
Uummm... I think he means the cover? It's been on this site before.
May 24, 2004
7,228
CC 30 South Florida
Spill the beans? In the inside I just clean the grill rack by scraping with a cleaning stone and then wipe it clean with a rag. For the outside I just cover it up after it cools down. As far as the cover I will replace it periodically. As you can see I do not do much and my grill looks no worse than most I have seen. Have you tried cleaning burnt grease off stainless steel? It requires time, dedication, patience, lots of elbow grease and an abrasive cleaner. Fail to do it one time and you get so far behind you do not want to do it again. It takes a while for the inside of the lid and the rack to get cured and to produce that good taste and you do not want to interrupt the process by scrapping it clean.
Aug 17, 2013
1,343
l'll try the easy off, I just want it to look presentable and the grease stains are looking ugly
May 24, 2004
7,228
CC 30 South Florida
I have heard of a couple of incidents where persons have ingested the bristles ending up requiring surgery to stop life threatening infections. A cleaning stone is a lot safer.
