A correction here from the admiral : the tools are not sitting in a drawer, rather the removable tool trays are sitting on a removable shelf. This shelf is accessed from the counter top and can be totally removed when working on the engine. And to completely remove the tool shelf, the front panel to the engine compartment that has the stairs on it needs to be removed.
Pateco : the product used for insulating is - Technicon Insulation FB-1, 32" x 54" x 1" per sheet and 2 pieces/sheets were used.
The day the boat was viewed there was no pervasive diesel odour. One week later, when there for the survey, the whole boat smelled as if it had been dunked in diesel fuel. Apparently the PO's mechanic at the marina had worked on the engine.We really wanted the boat and the survey was very good and we mentioned this to the PO and he had it cleaned up. Before bringing it to it's new club, it got a good cleaning with the orange degreaser and so we thought that would resolve the odour. We went ahead because we truly wanted this boat and the day after moving it, my husband discovered a leak in the hose and promptly replaced it. We don't regret the purchase at all and are used to renovating as we have done two houses. It's nice to know things from the inside out and helps that the Admiral is so handy. Otherwise, we would not have purchased the boat. Cheers!
