Need some help on checking fuel pickup for screen
Oct 1, 2007
1,865
Hi all:
I would like to check my fuel pickups for screen on my 2007 44 DS. Enclosed is a picture of what they look like. When I look at the tank, which is plastic, I see only the top of the pickup and a large nut on the threads. So do I loosen the nut and it will come out? Or is there a threaded boss on the inside of the tank? The nut is flush to the tank outer surface
Thoughts?
Thanks
Rick
208
Hunter 410 Dover NH
It screws right out of the tank. Leave the valve or fitting in until you break it loose in order to avoid deforming the opening in the aluminum fitting. I just did my 410 last month. There was no screen. I did find plastic shavings from tank fitting install between the pickup tube and the shut off valve and also in the 90 degree fitting going into the racor from the tank.
This is my thread from earlier.
http://forums.sailboatowners.com/index.php?threads/410-fuel-tank-question.180327/
1,865
Hey Scott and thanks for you very helpful post. The pickups screw off just as you said, so I was able to inspect them. Mine have screens on them but they were perfectly 100 % clean. I'm trying to troubleshoot a problem where my generator stops suddenly.
Aug 17, 2010
208
Hunter 410 Dover NH
My previous experience with screens on the pick up were similar. The engine would stop the junk would fall off the screen and the engine would run again until enough stuff collected on the screen. Did you remove the screen? Did that help? I always remove them. You must have a filter prior to the genset right?
I most recently found the fittings on the tank side of the racor nearly plugged thats another possibility...
Aug 17, 2010
208
Hunter 410 Dover NH
Did you figure it out?
Oct 1, 2007
1,865
Well, my latest "fix" was to tighten all the connectors on Panda's "temperature switches" on the Kabota which are supposed to shut it down for over temp. Seems ok. Pretty sure its not a fuel problem. We'll see. Thanks for your help.
Aug 17, 2010
208
Hunter 410 Dover NH
Would you not get a light on the panel for over temp? My Panda panel has several warning lights associated with shutdown including temp.
Oct 1, 2007
1,865
One would think so but I'm thinking there is something in the logic that is shutting down the engine. I know for sure the temp switch on the rear bearing is bad and indeed it lights the over temp light on the left end of the panel. But I'm thinking there is an intermittent problem somewhere that shuts it down and right now I'm focused on the over temp switches. I've replaced all the relays and the shut off solenoid. Not much else to replace.
Aug 17, 2010
208
Hunter 410 Dover NH
Does it restart right away? I had a problem with my Panda 4200 where the fuel pump relay was not seating right and would cut out. Can you jump the switches out for testing purposes?
