I don't claim any expertise in fresh water sailed boats, other than knowing zinc anodes aren't the right choice
Well if you have some Aluminum in the fresh water, Magnesium anodes are better. The rate of loss of your sacrificial anode is
slower in Fresh water than Salt water.
Galvanic corrosion works on your metals below water except if you are sailing on
Lake Distilled Waters.
You can use Zinc, Aluminum, and Magnesium (listed Noble series order) anodes to protect Steel keels/shafts and Bronze props in fresh or salt. I just can't afford $$ the Magnesium
rate loss in salt water.
I drilled a 1/4" hole in it and installed a 3-13/16" flat rudder plate anode to it as well
Great Job!
Tip:
Rate of loss of anodes is the ratio of
anode surface area exposed, to the
exposed metal surface area you are protecting. Weight of the Anode provides longevity between changes.
On Allan12210 picture,
painted iron keel reduces the surface area of exposed metals to galvanic corrosion.
Jim...
PS:
@Allan12210 separate the egg Zincs slightly to expose more Zinc surface to water.
