Rebuilding rudder help
The bottom paint sounds like VC 17. It must be removed before proceeding. 80 grit sand paper on a random orbital sander will make short work of it. Collect the dust, copper is not anything you want to breathe.
Nov 9, 2008
1,338
The epoxy paint is to create a waterproof surface. FRP by itself isn't waterproof and can develop blisters due to osmosis. So a couple coats of barrier paint will go a long way. Probably $50 per quart. Then you put on the bottom paint.
-na -NA Anywhere USA
Army Aviation;
Generally the rudders are two halves with either a wood or foam core married together with marine putty and then covered with fiberglass. It is obvious over the years that due to wear and tear and who knows what ever, that you have issues. Good advice given but as a servicing dealer who repaired many over the years, the first is to let it dry out which you advised it did but to many let the rudder stand up with a hole for moisture or water to escape in a dry place out of the sun. Not knowing what you exactly have, I would remove all the old paint or coating that is on it wearing masks outside with a cover on the ground or using a dust collector style sander such as a palm sander with filter attached down to the gel coat. At that point I would apply a two part epoxy to fill in the holes and depressions. I use to buy Watertite by Interlux and yes it is expensive but sure does last but most important is a slow cure and to be blunt the hardest and long lasting. Then spray light with some paint over any major voids if large and then wet sand to see if there are any valleys left that will need a second coat. Then you will need to build up the fiberglass as suggested on the leading and bottom edge of the rudder. You will probably will not be able to do this in one session but two or three times since you are not on a flat surface when applying. Sand between finishing. When finished with that, I use to take the two part epoxy and fill in the small pores and any other depressions and give a final wet sandpaper sanding. At this point apply several coats of barrier coat. Depending on keeping in the water or trailering the boat will depend on applying bottom paint but remember some anti fouling paint properties will last up to 60 days out of the water while others will last on the anti fouling properties no matter what. In addition when storing any rudder with dark colors on a rudder, do so out of the sun as the heat build up in the rudder will be affected by direct sunlight. I hope this helps.
Never heard back from you but I appreciate your service in Army Aviation.
Aug 4, 2015
62
American fiberglass 21 My driveway enterprise, AL
Thanks for the help Dave, I actually talked to you on the phone for a bit last year. Haven't got to see your dads memorial yet and I believe that hobby shop is gone.
Sanded and glassed the rudder this past week. I am going to apply first coat of epoxy tonight.
Btw. Someone has worked on it before evident of the glass where the pole runs into the rudder
