Your fresh surfaced Zinc and Shaft galvanic corrosions stabilizing. If you dive a few hours later and still bubbling, you most likely have a stray marina electrical current. How badly was your old Zinc gone?What gives?
Upon what do you base these statements?Your fresh surfaced Zinc and Shaft galvanic corrosions stabilizing. If you dive a few hours later and still bubbling, you most likely have a stray marina electrical current.
Master Degree in Chemical Engineering that takes two minors in chemistry, but as all advice from me, it is worth what you paid for it.Upon what do you base these statements?
Jim...f you dive a few hours later and still bubbling
OK, but what is off-gassing and why is the anode doing it?Master Degree in Chemical Engineering that takes two minors in chemistry, but as all advice from me, it is worth what you paid for it.
Galvanic corrosion is a battery "discharging". To come to "Steady state" galvanic potential from a fresh zinc and stainless shaft make take a few minutes for the new battery to arrive at steady current flow. Depends on surface area of zinc to shaft ratio, temperature and salinity of your water.
My guess is that in the store Zinc turns grey from Zinc Oxide. As the battery discharges to be Zinc again, Oxygen is the bubbles.OK, but what is off-gassing and why is the anode doing it?
Not a clue. Assuming it's mild steel.FastBottoms
Do you know the recipe of the brush - iron, stainless, brass, whathaveyou?
Charles
So this test is to see if there's any current leaking?Ken
You need actual data.
Check the potential of the shaft. Zinc reference probe on a wire goes overboard, VOM set to volts, reference probe wire to VOM -, VOM + to the shaft. Give us the readings.
Absent actual data the ideas mentioned so far are not very useful whereas this simple test will clinch a diagnosis.
Charles
Martyr anodes? Made in China. Sorry.I've been fitting this good quality Anode (not the China made stuff) and this is the first time I'm seeing off-gassing on the Anodes.
Yes, but you indicated that Chinese-made anodes are inferior, not me.....iPhone is made in China as well
That suggests to me, 100% gone, as a protective Zinc anode. Not in electrical contact with the other metals. If you dive your boat again, and it still bubbling, then we can talk about size of anode and what Charles suggested... a complete Galvanic survey of your boat.The old one has about 40% left and as I brush it, it crumbles
