hope someone can help, i have a 16k btu cruisair with separate condenser. sometimes it is stubborn starting. i have to give the circuit panel box a tap and it will start, compressor, water pump and fan. originally i thought the low or high switch connection was bad because they are just punched down on the circuit board. but that would show a fault on the thermostat. i can hear the on board relays click on, but no action. on top of the box are 2 capacitors and a relay. i feel one or more of these is the culprit. anyone else have similar issues?
mike
mike
