Have you ever come across any literature on UV effects on 3M VHB tape. I know that silica glass (window glass) is a good screen for UV but acrylic is not. Wonder if you get any degradation in time under the acrylic. If that's the case, you may want to use a narrow strip of 3M VHB tape to position and act as a stand off for the acrylic, and rely more on the 795 for mechanical adhesion. I have GOT to get a handle on my OCD.
Did you ever see this video ? The best I've seen for fixed port installation. Most others are bad to completely useless.
http://boatworkstoday.com/archives/1735
This guy is so good in his setup and yet he completely missed using blocks of wood glued in place with hot-glue in order to exactly position the acrylic before dropping it on the 3M VHB.
I'll be checking on your restoration for further ideas on port replacement.
