higher water levels cause stanchions to catch on pelican pole cleat
Aug 6, 2013
4
Hunter 34 Manitowoc
We have a 1986 Hunter 34. The top of the stanchions stick out about 2 1/2 inches wider than the hull. When there is a strong west wind (also compounded by our prop walk), we get blown into the pelican pole when leaving and coming into our slip. In the past, we just kind of rubbed and got past it. but now with Lake Michigan water levels about 2 feet higher, our stanchion at the beam gets caught on the cleat on the pelican pole. It bent it about 5 inches. We purchased a new one but are wondering what we can do to avoid this in the future. We don't want to also bend the new one. The cleat sticks out about 2 1/2 inches. We need something at least 5 inches between the boat hull and the pole to keep from getting caught.
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Seems like a fender could work, but post a photo of the stanchion and toe rail, I'm having a hard time picturing it. Thanks!
Jul 7, 2004
8,525
Hunter 30T Cheney, KS
I thought it was just me. I'd like to see it too. "fenders" was my thought as well.
Feb 20, 2011
8,062
Anybody else find it odd that the stanchion sticks out further than the rub rail?
Nov 6, 2006
10,200
Okaay.. The base of the stanchion is not horizontal. It is sloped with the deck, so the stanchion is not vertical.. it slopes outboard a couple of inches at top and as in this picture, it can easily catch on pilings etc and get bent just as mine is, damnit. You can see the second stanchion is vertical, the base of which shows the bending it got when it caught on a piling. you can see the ones forward of the bent one leaning outward a bit. It would take something about 8-10 inches in diameter, like a big bumper hanging horizontally, to stop them from catching.
8,525
I think the layout is understandable. Just not sure why a correctly positioned fender couldn't protect the boat from a cleat?
Nov 6, 2006
10,200
Might be good to consider moving any protrusions like cleats to the fore/aft sides on the poles instead of on the "inside" of the slip..
Feb 8, 2014
1,300
Columbia 36 Muskegon
2 1/2" does seem like a lot. Often the stanchion bases are angled slightly so they point straight up or slightly inboard. Flat bases will angle out but usually not that far. Perhaps these are angled bases but some PO has turned them around the other way?
Nov 6, 2006
10,200
nope.. that is from Hunter.. It is actually very nice when using the deck when heeled over since the lifelines don't interfere with the limited deck space as much as a vertical one would. This is the base on the down-angled rub rail.
What if you attacked this problem from the pelican hook side instead of the stanchion side of the conflict? Put the bumper (or guard) on the cleat.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
What is a pelican pole? Is it simply a piling? I know what a pelican hook is.
Feb 8, 2014
1,300
I've never heard them called that either. Not too many pelicans on Lake Michigan, though there is a small colony of them on Green Bay.
I can understand the concern now that I see a picture. Life lines look a bit like the out stretched fingers of a baseball glove. I always tried to form my glove around the ball by wrapping it, getting the fingers to bend in so I would catch and hold more fly balls.
Why can't you measure the angle and take the stantions to a pipe fitter or metal shop and have them tweek the poles so they stand verticle. Would be a bend about 2 inches above the base fitting. Seems a straight forward fix. The benefit would provide nothing hanging out beyond the boat edge and when going forward to the bow might be a bit easier to grab the life line on those slanted decks.
Nov 6, 2006
10,200
:laugh:Pelican poles.... Like this, except on your slip poles..I know Woody has 'em because this is about 15 miles south of his slip..
Likes: woodster
Jul 7, 2004
8,525
We have pelicans in the migration season but they don't sit on poles. :tongue:
I'm guessing they are dock pilings.
Do not know about Pelicans, but Storks and Herons look like they are carrying their own poll when in flight...
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
here is our local pelican chow hound
this is Henry ....she hangs around the pier and waits on the cast net guys to feed her (yes her... they thought for a long time henry was a boy until HJ came along Henry Jr. )...she had a broken wing and a man rescued her ...bring her back to good repair ...he had a bicycle horn that he used to honk and she would come running if she was in earshot......this bird has some really good color and markings ....and is everyone's favorite here at the pier....i am about 24 inches from her win i took these.... this morning......but you have to be nice and slow to do this if she doesn't recognize you or she will spook or even snap at you ....
edit: i will add that the light was not very good because of the overcast this morning ...i will get some better shots so you can see the good colors
5,180
Bavaria 38E Alamitos Bay
A pelican standing or roosting atop pier dolphins and dock/docking poles of residential-area canals, and elsewhere, is an iconic sight along the Gulf coast, at least. So much so that the City of St. Petersburg, FL has incorporated the image into its Seal of the City and its advertisers into their touristy banners, so the term "pelican pole" might have come into use around there (or even independently in a number of communities). It's as good a name for 'em as any! Of course, that does not answer the question of how to keep the stanchion of a Florida-built boat from fouling the "cleat" of a Florida-esque "pelican pole" in Lake Michigan? :confused:
