Evening all !
I'm in the process of refinishing/ varnishing the teak on our 1987 C22, including the rails that the main hatch slides in.
The fiberglass hatch itself has cracked and has damaged coring.
Since i'm doing this, I figured I should improve them.
The edges of the hatch, which slide in the slots in the teak rails, will obviously need to be built up a bit with glass.
Any cool ideas on improvements ?
Line the slot in the teak with an aluminum extrution ?
Bond some plastic of some type to the bottom of the slot as a nice glide surface ?
Use a couple layers of clear epoxy in the slot, before I apply the varnish ?
