I have a 1999 Hunter 376 Sailboat I bought in January 2016. I have one 75 gallon fresh water tank.
I was having water pressure spitting out air. So I replaced the 1998 Shurflow water pump. I purged system by over filling tank to flow out of air vent. Water pressure was good for awhile.
It appears when tank gets to be between 3/4 and 1/2 full, water pressure spits out air and pump won't shut off when faucet valves are turned off. I have to switch off breaker. And repeat filling up tank to flow water out of vent to purge air out of the system.
Things I noted about my fresh water plumbing system.
1) My bilge is dry.
2) My water filter before water pump suction is clean.
3) My water supply piping suction line is connected at the bottom of water tank. (no leaks detected).
4) I have searched all over for water leaks. None have been detected.
1) My bilge is dry.
