I'm a proud new owner of an '88 Hunter 28.5, it's in pretty good shape.
However, I'm trying to remove the two Harlow self-tailing winches for the jib to lubricate them. I've already re-greased the halyard winch (3/16 allen head in the middle). However the two self-tailing winches have a very thin headed 1/2" bolt in the winch handle hole, and I've discovered that it takes a narrow walled 1/2" socket. I have a socket with a 1/4" drive that does fit. Problem is, I can't seem to hold the outer shell in order to remove the bolt.
I tried to use a screwdriver propped up against the ridges against the tail, but the ridge just broke off when I tried to put pressure on it. Any other ideas on how to get the winch bolts out?
Do I dare remove the bolts from underneath and take the whole winch off so that I can bring it home to work on it?
Mike
Mike
