Frozen locknut on Stuffing box
Aug 14, 2011
182
Hunter 35.5 Legend PCYC Shediac, NB
The locking nut on my bronze stuffing box is frozen. I have brushed away all of the green oxidization but still unable to back the locknut off. The inner most part closest the engine that contains the packing I was able to get loose and turn. But I have a little too much water dripping and need to tighten the unit.
Any suggestions on how to free the locknut on the threaded shaft ?
Thanks
Dec 25, 2000
5,950
Ditto ours, too. Soaked two or three times with Liquid Wrench. Tap the flats a few times during this process. Give the Liquid Wrench time to do its work. A Service Wrench of the correct size works the best; one for the box and one for the lock nut. Ours are a different size for each; 2" for the box and 2-1/16" for the lock nut. I also use a ten inch piece of SS tubing that slides over the Service Wrench handle for greater leverage. Pipe wrenches, adjustable wrenches, etc., were just worthless, IMHO.
http://www.amazon.com/Stanley-J3560-Pattern-Service-Wrench/dp/B0025PM1G4
2,366
Try pouring some hot water over the nut then follow by liquid wrench or pb blaster. Tapping flat of nut along the way. Thats how i undid mine.
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
PB Blaster is the best IMHO. It may take several applications and a day or two to work.
Aug 14, 2011
182
Thanks guys I will try that. I did try the PB blaster but only gave it an hour. I will apply it a few more times and give it some light taps.
Have any of you tried replacing the packing while in the water ?
Mine was stuck due to a no maintenance practice of the PO. Friend suggested taking a piece of rod and using it to tap the edge of the nut to give it a nudge in the right direction. It worked. We got the nut to move and berak loose.
Feb 8, 2014
1,300
Columbia 36 Muskegon
The packing can be changed in the water, but if you've never changed it before in the water is not the ideal place to learn. Cold seawater spraying in your face, water flow trying to push the packing back out, etc. It's much easier on the hard.
And if you're hauled and still can't get the nut loose, maybe you can pull the shaft and take the whole thing out of the boat where you can actually get some tools on it. And of course, once it's out you might as well replace it with a dripless model so you never have to do this again.
Nov 22, 2011
1,272
Ericson 26-2 San Pedro, CA
PB Blaster is great stuff, but keep it off of any rubber parts, such as your transmission seals. It's reportedly not good for the rubber.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
Also make sure you're turning it the right way. The locknut likely needs to go clockwise to release, contrary to instinct, and opposite the packing nut.
weinie
Sep 6, 2010
1,297
Put two pipe wrenches on it. Whack the turning wrench gently with a hammer. The metal on metal clang will loosen it.
If not to worried about the water, adequate bilge - battery - and working pump, you can wrap a rag tightly around the shaft and it serves to minimize the water ingress. I have heard folks dive under their boat and stuff a plastic bag up and around the shaft to provide a weak seal. Remembering to go back in the water and remove the plastic bag is important.
We used the rag method and it was not a scary experience.
Nov 22, 2011
1,272
That looks like a great way to keep the water at bay. Might have to try that
It is going to vary with the boat, I suppose. On my previous boat (a Catalina 30) and my current boat (an Ericson 26-2) my bilge pump *easily* keeps up with the flow--and my E26 has a very small capacity electric bilge pump. I can take all the time I want changing out my packing. In your case, the first time you do it you may wish to have handy a way of reducing the flow should that prove necessary. But my guess is that it won't.
Alan's right. The amount of water that comes in is so negligible as to be laughable. If you must, wrap it with a rag.
This is a complimentary article, with a link to Maine Sail's website and types of packing.
http://www.c34.org/wiki/index.php?title=Stuffing_box_packing
If you haven't yet, get a bronze wire brush and treat the threads aft of the locknut, too.
182
I love this forum. So much valuable information and experience being shared. The nut has been released and I am back in business.
What do you treat the threads with to keep them free since this is bronze
Feb 10, 2004
4,184
I would use a bit of waterproof grease like Lubriplate or SuperLube. The locking nut when tightened is going to hold everything from loosening, so I don't think there is a safety concern.
Jan 4, 2006
7,424
I agree with Rich's suggestion of Superlube but in addition, undo the locknut once or twice a year to ensure it doesn't freeze in place in spite of the lubricant. All that salt water slopping over the threads can still cause problems.
2,391
Hunter 28.5 Chesapeake Bay
Many years ago when I bought my first boat with an inboard engine, I took a course on diesel engine maintenance called "Diesel Dorks." It was very useful, even today. At one point, the instructors got into packing gland maintenance and the subject of frozen locknuts came up. They said to give the nut a hard whack on one of its flats on the nut (in the right direction) with a ball peen hammer. Some may shudder at the thought. Some years later, I had an aging Cat 27 with a frozen lock nut. I tried all the lubes and blasters, et al, at first. Nothing worked. Then I whacked it with a ball peen hammer. It worked.
