Not talking about cove/shear stripe. Look at the small white stripe on the top third of the boot stripe. That's what I working on. I know his was likely molded in when the hull was made, but I've had to completely repaint everything above the waterline.Cove stripes don't wrap around the bow. Check out John's pic. Do it like that and be done with it.
Gotcha. I painted my boot stripe on and didn't get fancy using multiple colors. Just one color. I didn't care for the idea of a vinyl boot stripe.Not talking about cove/shear stripe. Look at the small white stripe on the top third of the boot stripe. That's what I working on. I know his was likely molded in when the hull was made, but I've had to completely repaint everything above the waterline.
Bigger problem to worry about now - I tried applying the white stripe by measuring down from the top of the boot stripe every 8" or so, and ended up with what looked like a kiddie roller coaster! ( btw, I decided against the 2nd shear stripe)
