I need to replace the bulb for the deck light on my 2003 Hunter 386. I would like to go up the mast only once with the replacement bulb in hand. Does anyone know what the proper replacement bulb is?
Good idea.Perhaps someone can help if you could post a picture of the fixture. I replaced our incandescent bulb with a LED deck light bulb from marine beam. Whether yours is the same, a photo of your fixture will say.
https://store.marinebeam.com/high-powered-ba9s-deck-steaming-light-led-ba-9s-5w/
It is NOT the boat size and vintage but supplier of the fixture. Mine is HELLA too. If you look for this type bulb.Hunter of similar size and vintage.
Can you post a picture of the old bulb? Is it a standard bayonet style, or pin, or something else?I just changed mine out. It is a GE 4406 tractor
