I think a lot will depend on your slip, and the conditions of the location. Where the wind tends to come from, are the waters protected from the elements, i.e. is it calmer by the dock than out on the lake, and so forth. Also, do you like to stern-in, or bow, and all that wonderful stuff.
I have a 26', and dock on my starboard side. Fortunately, I have a marina with a good floating breakwall and protection, so even on really windy days, it's much calmer inside. Bumpers on the side before I come in, and I run a dockline from my bow cleat, and lay it back down to the shrouds, draped over the lifeline. I also have another from the stern that I run up and place it nearby. That way, I can grab both lines at the same time. So my single-handed approach is to simply slow down as I turn down my lane, blipping into forward than back to neutral, just enough to maintain speed and steerage, until a couple boat lengths before my slip. I time my turn so I'm making a 90 into the slip with the bow just to the inside of the dock. If I'm not going slow enough, I'll bump reverse just before I turn in to scrub speed. Then it's to neutral, and I leave the cockpit, jumping up  midships and picking up the ends of the lines, hopping off onto the dock. At that point, I'm just arresting forward motion with the bow line, and the stern line is simply to keep the stern from kicking out away from the dock. I displace about 4000 pounds, so I do have to be aware of the weighted momentum. While it's not a heavyweight, it does take some effort to stop it. Nothing too crazy, but enough. I have another line on a dock cleat that I run to the other side of the bow, that stays on the dock so once I'm in place, I toss it up to the bow and cleat it off. Unfortunately, I have three points of tie, not four - there's not a piling between the slips, so I'm not able to let her float in the middle, but it's protected enough that it's all good.
