I have one on order and will post when I install.Along the same line I, too, am planning on installing the same autopilot. My question is how did you mount the rudder position sensor, if you mounted one. My previous AP was many years old and essentially self-destructed hence the Raymarine replacement. Any pictures of the sensor mounting on a Mk1 Cat 30 ('84) would be appreciated. Still working on the STng backbone routing in anticipation of future needs. But that's another story.
There is no rudder positioning sensor, but I was told that they are a little more accurate with one which could be added to the unit but I do not have one on my installAlong the same line I, too, am planning on installing the same autopilot. My question is how did you mount the rudder position sensor, if you mounted one. My previous AP was many years old and essentially self-destructed hence the Raymarine replacement. Any pictures of the sensor mounting on a Mk1 Cat 30 ('84) would be appreciated. Still working on the STng backbone routing in anticipation of future needs. But that's another story.
That's the same pod I used, be careful they break easy that's why I put the hardware on mine to stiffen it up.Just finished the install on my 30. I put the control head on the pedestal using the instrument pod from Defender. (see link) I mounted the pod upside down so it didn't sit above the grab rail. I did this to keep it from being grabbed by somebody. I had to drill a hole in the pod for the wire. The arc at the top of grab rail is too sharp for the pod to fit perfectly but it is secure. Ran the spur down through the pedestal using a16 ft. black and white I ordered from Defender. The Pilot sits below the arc very well. The 16 ft cable runs under the quarter berth to the junction block just under the nav station. The ACU 100," aka brain" sits next to the junction block .The blue backbone runs from the junction block trough the wall of the battery box, under the battery box forward through the water tank locker into the hanging locker. I used a T and ran a white/black cable up to the forward top of the locker and mounted the sensor, AKA compass, up high out of the way. I used a compass app on my phone to calibrate the heading of the sensor by reading the Pilot, aka control head. Works well with everything out of the way.
What was/is frustrating is the lack of directions, written poorly and written for a previous model. Pain in the butt reading them
http://www.defender.com/product3.jsp?path=-1|344|2028704|2028919&id=2397625
Yes you can. Among the discordant manuals they enclose the old st 4000 manual. I thought I had received a returned unit and sent it back.Hey Guts - I'm installing an EV 100 also on my Catalina 30 Mk II. I have an Autohelm ST 4000 now - do you know if I can use the existing wheel drive and motor? I'd appreciate getting some photos if you can send them along, I'll send my email by private posts. Thanks for any help you can give!
I never got your email if you send it to me in a PM I will forward off the pictures that I sent to the other 2 requestsHey Guts - I'm installing an EV 100 also on my Catalina 30 Mk II. I have an Autohelm ST 4000 now - do you know if I can use the existing wheel drive and motor? I'd appreciate getting some photos if you can send them along, I'll send my email by private posts. Thanks for any help you can give!
If you look to the right of this picture you will see there's a fiberglass piece below the steering quadrant mechanism I have everything tucked in there but there's also the T that is outside that I can access for another backbone cable if needed.Where is your seatalk switch with all the cables?
