Unknow device found in 1979 H30....
Hunter 30_74-83 Rochester, New York (Lake Ontario)
Ahoy,
Does anyone know what this device is or what it's function may be. I think it may be telling in that it has posted on a component "N1 88.0 Khz". Does anyone recognize this, I have only began to trace it and have not gotten to the source yet as it is routed through the crevices of the boat.
Thanks,
Bob
Nov 30, 2015
1,343
It looks to me, based on the circuitry that it is a flow thru temperature sensor (albeit homemade, and using the original Japanese designed board) with larger thermocouple inside the elbow/coupling and calibration pots on the board. Perhaps a temp sensor for engine cooling water or the hot water heater. So Benny's assessment is spot on...trash!
Where in the boat is that?
Kito,
In the process of re-powering I have been going over the entire boat. This was found aft laying on the bottom of the hull just slightly before the steering quadrant. I can't believe this was "a place for everything and everything in it's place". I have no idea of where it may have resided originally. Oh well.
Cheers,
Bob
Nov 30, 2015
1,343
The board was built by Japan Radio Company (JRC) but this doesn't appear to be related to any radio device (no crystals on circuit board). There's clearly some sort of housing missing for the board as well.
Nov 6, 2006
10,229
Wife tells me to throw it away.. I put on my aluminum foil hat and tell her that when the North Koreans shoot down the GPS satellites, and our gubmint finds and knocks the kudzu vines off the antennas, we'll still be able to navigate.
I still have my sextant. Unless Kim Jong-un can shoot down heavenly bodies, I should be OK. ;)
Mar 5, 2012
152
Hunter 37-cutter Saint Augustine
anyone can clearly see it,s a homing device made in japan. perhaps wwII era found on a sunken jap submarine in the pacific. if you could only power it up what stories might it tell ?????
Mar 5, 2012
152
wait after looking closer I failed to see that it is in k-heartz so it came out of one of those transistor fm radios from the sixtys
Nov 30, 2015
1,343
Aluminum foil hat = radar tuning...
Likes: kloudie1
Sep 3, 2012
195
Hunter 285 Grand Rivers Ky
Could you send me a photo inside the plastic piece? It is intriguing to figure this stuff out. I think I know but need to see a little more.
Ahoy,
Thanks,
BobView attachment 121900 View attachment 121900
Jeff,
I will be at the boat tomorrow and will take a few "profile" pics of the plastic piece and post them tomorrow, late afternoon.
Bob
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
could be a dimmer control board for one of those old chart table lights
zeehag
Mar 26, 2009
3,198
dimmer control for loose nut behind wheel of boat....... oops...
Likes: woodster
Jeff,
Here are a few more pics. At this point I believe a piece of an old LORAN sounds like the most likely probability.
Cheers,
Bob
5,948
Oday 322 East Chicago, IN
The plastic base looks like it mounted on a rail....what does a GPS antennae look like inside the plastic dome?
