Like in the post above, the thru hole can wind up below the waterline with weight in the cockpit or with following seas hitting the transom. I like the piece of mind with a closeable seacock there.
Interesting idea. I can see advantages in that as a back-up incase the hose should fail. Having had a V-222 and now a Mac 26d but not a V-25 I'm curious as to the accessibility of such a seacock. Neither of the Macgregors that I've owned would be accessible during an emergency.Like in the post above, the thru hole can wind up below the waterline with weight in the cockpit or with following seas hitting the transom. I like the piece of mind with a closeable seacock there.
the access to that area is very limited in a macgregor, so the addition to a valve there would be pointless (and there is not the room to install one). and yes, when pushing hard with the motor the stern squats, but no to the point where it fills the cockpit.... but if the boat is loaded a bit heavy in the rear, it can get an inch of standing water at the rear of the footwell... so the drain IS going to be submerged at this time, when normally it is above the waterline.Most boats also squat down when motoring, especially when pushed to hull speed. That can put the through hull under water continuously, which would fill the boat really fast.
That's one question that has been wandering around in my head.Yes, but is it a good idea.
lol, Remind me to keep you away from my boat.....Only the owner can say. I kind of enjoy drilling holes in the boat, especially if its somebody else's.
I agree. Lots of thought goes into anything, especially drilling a hole in a boat. But, I was not thinking 6 inch, maybe 4 inch. I have very skinny armsThat's one question that has been wandering around in my head.
The other question would be "Is it worthwhile?" I've installed deck-plates but not in my Mac. I spend days contemplating pros and cons before I drill even a tiny hole in my boat. Just imagine how much time I'd need to think about cutting a 6" hole for a deck-plate.
That answers my question. With access like that a seacock might be reasonable.My V25 has open access ( except for stuff I store in that area) from the starboard cockpit hatch all the way to the transom. I know some of the 25's have a bulkhead in there that limits access to the rear, which one could remove or make an access door in.
Not below the waterline, but close enough to worry about.If I understand correctly the hose from the cockpit sole to the transom drain on Mac 25, below water line, is not connected? If this is the case then when the boat is in the water the hull should flood, quickly!
Quick Question. How did you mount your battery box? Thanks in advanceMy V25 has open access ( except for stuff I store in that area) from the starboard cockpit hatch all the way to the transom. I know some of the 25's have a bulkhead in there that limits access to the rear, which one could remove or make an access door in.
The routing of the hose will normally create your "flattened" area, but should still drain quite well. Mine also has the flat area, but I've not found it to hinder drainage.Clearly it is not the original since it is a Dayco Flex Hose. The end that goes to the scupper is flattened, but not closed. It was full of water when I removed it.
