OK. So I decide to replace the packing material in my stuffing box as it has not been done yet since I bought Mystic in 2013. I read all the posts and studied the process to death. I bought the 3/16 flax and today I dove in to get it done. I am having an unexpected problem as I am having a seriously difficult time getting the big nut loose that holds everything in the packing box. All of the threaded surfaces are moving fine. The friction appears to be between the packing nut and the prop shaft. I polished the shaft as much as I dared to reduce friction but I have to really use muscle to move the nut. The threads are fine and nothing is stripped as I moved the nut back up the shaft just to check. I would like to ask the group for wisdom or to see if there is something I need to look out for. I don't want to force this and cause a nasty expensive repair by doing something stupid. As always all wisdom welcome.
