Cleating the anchor rode
Iluna
Mar 2, 2016
3
Hunter 31 Harpswell
The owner's manual for our 2007 Hunter 31 says that the cleats on the deck are the "strong points" and that we should not use the cleat in the anchor locker if the boat is left unattended. Why is the cleat in the anchor locker not as strong? What can be done to "beef-up" the anchor locker and or its cleat?
Feb 10, 2004
4,256
Hunter 40.5 Warwick, RI
I always use the anchor locker cleat to snub my anchor rode on my 1997 h40.5. I have never seen any warning to the contrary. If anyone has different info on the 40.5 please post.
Jun 11, 2011
1,243
Hunter 41 Lewes
If it rips the cleat out, as long as it and the rode stay together, it's not fitting through the bow roller assembly. :biggrin:
Likes: Allan12210
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I'd suggest to look at the cleat backing in the anchor locker if you can. If it relies on a thin FG floor or small doublers, it may require you to beef it up.
I once had a trailerable with bow eye pulling out. A little fiberglass cutting revealed it was mounted in wood with a tiny washer about the size of the nut. It was pulling through the wood. It would have been easy to loose a boat o the highway that way if one forgot the transom tie downs, or just pulling it up a steep ramp before the transom was tied down. When in doubt look for yourself.
Ken
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
I always thought the cleat in the anchor locker was provided as a convenient place to tie off the bitter end of the anchor rode, and was not intended to carry the loads of the boat at anchor. I use two nylon snubbers from the bow cleats to the all-chain rode.
Dec 25, 2000
6,071
No anchor locker cleats on our boat. The bitter end is secured to a large SS eye bolt that extends through the stem. Very strong. I always secure our anchor rope to a bow cleat, also very strong.
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
Cleats are supposedly designed to hold loads along their length-wise (fore-aft) direction, i.e., normal to the fasteners; not to be loaded "up" or "out" vertically, or even to be side-loaded much. Although, some empirical testing on 6-inch cleats mounted on steel plates suggests that might not be universally the case; i.e., angle of pull not the important factor. Nevertheless, cleats inside the anchor locker might not be best oriented to safely hold a high load on the ground tackle whereas the ones on deck should be.
Likes: kaptainkenny
Kermit
Jul 31, 2010
5,722
Interesting info here. Silly me. I have always relied on that cleat for holding power. Durn all y'all!
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
I have one tie off for the bitter end and a cleat to tie anchor line from windlass all in anchor locker and been using since 2007 and never had any problems in some very windy conditions at anchor and yes also also use a double line snubber to my chain.
Feb 20, 2016
8
Hunter 33 Anacortes, WA
.... I use two nylon snubbers from the bow cleats to the all-chain rode.
Tom...how do you attach your snubbers to the chain? I am new to cruising, looking for a simple/clean way to accomplish that...we just took delivery of a 2005 H33, and are looking forward to our first overnighter as the weather improves...
Jim
Dec 25, 2000
6,071
Jim
Hi Jim. Congrats on your new boat. Where do you plan on your first overnighter?
Feb 20, 2016
8
Haven't got that far in the planning yet...:biggrin:
We are mooring in Anacortes Marina, so will likely be somewhere like Sucia Island...went there on the Bare Boat charter training last year, liked it a lot. Got a few things to do first, like finish the physical part of the renaming process and getting comfortable sailing her locally....probably toward the end of March will plan a two or three day trip.
Dec 25, 2000
6,071
Not likely to slip out regardless of tide state. The weight of the chain to the bottom will always be sufficient tension. Although some people like the idea of a belt and suspenders.
Echo Bay on Sucia is a wonderful place. Lots of mooring balls to choose from but I prefer to anchor out.
Hope to see you on the water this season. I will look for you.
John Lund, an AMEE flotilla member, is on the north side of D dock. He has a Freedom 32 cat sloop. Say hi if you see him. Mark Maulden, a regular from this site, is there, too.
8
Nice....will keep an eye out for John. We are on D dock until Monday, then get moved to our more permanent slip on F Dock.
Feb 10, 2004
4,256
That was what I was envisioning, glad to have the sizing info...but was wondering if the grab hook would tend to slip out when the chain is not under tension such as slack tides etc. Would a hook with a catch, something like a snap shackle, be more trouble than it's worth?
I use a simple grab hook and there have been times when I have found it disconnected and just hanging when I raised the anchor. I am not really sure why it occasionally happens.
