Nigel is well versed in lightning avoidance. The zone of protection is real and needs your stays and mast grounded. That zone is called a Faraday Cage. Deep or shallow water grounding, may have a point, but any grounding is better than NONE.When you talk about "avoiding it" Nigel, talks about creating a "zone of protection" and how to do that (see attachment). It was in reference to this concept that I asked about connecting the mast to the keel bolts, and if they would provide grounding the necessary ground to water...if they had a direct path to create the zone of protection. Please, bear in mind that Nigel is NOT talking about carrying lighting voltages THRU the mast to the water....
True with one exception, you don't have a galvanic isolator on the AC green and some idiot sends a DC current down the shore power on the AC green.This rule - connect AC safety green to DC negative - is to keep people safe from an AC shock hazard on the boat. This has nothing to do with galvanic or stray current corrosion issues.
Jim...
