Thanks again to everyone on the forum that helped me lower my mast. I want to repair/replace/upgrade from the top down but rather than ask 20 questions I'll work on them 1 or 2 at a time.
First question, you can see in the picture the old VHF antenna. The wire going up the mast to it needs replacing and I might as well change the antenna also unless, Do I really need this and the associated expense and upkeep? I will be using this boat for coastal cruising, usually always in sight of land. I wouldn't do away with the VHF radio but would an antenna mounted lower on the boat make more sense?
Second question, also in the pic see a rusty bracket that I suppose held a windex. Really, do I need a windex? I mean as I feel the sails pull and feel the rudder do I really need to look up there for direction? I think possibly with my lack of experience it won't help much and once I have experience I won't need it. Thoughts?
