I I'm only behind the wheel when docking I am usually next to it or in front of it. I do not have an autopilotJohn, the "trick" is to avoid "being a slave behind the wheel" and letting your autopilot steer the boat. When I need to adjust my traveler often is going upwind. The boat should be reasonably balanced, reefed early, and the traveler "played" when necessary. During those times I'm always in front of the wheel. Going to beam or broad reach and downwind, the traveler is down anyway and needs no adjustment.
You might be interested in this topic, especially reply #16 by John, who uses his mainsheet. He'd also suggested making the traveler lines longer to reach the wheel in other discussions. I just odn't think it's necessary.
Single Handing 101 http://c34.org/bbs/index.php/topic,5445.15.html
Can you explain or show pictures how you accomplished that?Here's why I ran my traveler lines back to the wheel. Previously, my wife would complain the boat was heeling and asked me to get it back on it's feet. My response was for her to take the wheel while I adjusted the traveler. Here response was she'd take the wheel after I got the boat on it's feet!!! Anyway, lines to the helm solved that problem plus using the traveler is the quickest way to get the boat on it's feet in a gust. After the gust, you just reset the traveler to its previous position and go merrily on your way,
I just changed out the lines and made them longer to reach the wheel. The Garhauer straight track traveler (I got rid of the curved track traveler after a modification try to make it work) made adjustment easy -- I could release tension on the lines with a flick of the wrist and snap them back to lock quickly. I also had Garhauer make me a 2' winch handle (yup, I mean 2 foot) so I could trim the jib without leaving the helm. Those mods made my wife happy -- she didn't have to do anything but sit back and "catch ray's"!!Can you explain or show pictures how you accomplished that?
I have the same Garhauer setup. Where do you lay the lines, outside the coaming?I just changed out the lines and made them longer to reach the wheel. The Garhauer straight track traveler (I got rid of the curved track traveler after a modification try to make it work) made adjustment easy -- I could release tension on the lines with a flick of the wrist and snap them back to lock quickly. I also had Garhauer make me a 2' winch handle (yup, I mean 2 foot) so I could trim the jib without leaving the helm. Those mods made my wife happy -- she didn't have to do anything but sit back and "catch ray's"!!
JohnVTX: Mostly along the seats -- I needed them where I could easily get to them. 90% of the time it was just my wife and myself. If we had guests on board I'd leave the setup on the cabin top in hopes the guest would want to play with the sail trim -- most did but my wife would start on me when we left the home driveway to shut about about sail trim because no one gives a crap about it. As a result I never brought up the subject of sail trim unless the guests asked. Sometimes I'd try to bring it up but I'd get that "evil eye" that only gals can give!!!I have the same Garhauer setup. Where do you lay the lines, outside the coaming?
