Slotted or Phillips ?
CYQK
Sep 11, 2009
605
beneteau first 42 kenora
Replacing a bunch of fasteners do you prefer one over the other?
Thanks
Gary
Apex
Jun 19, 2013
1,223
C&C 30 Elk Rapids
what do you need? Torque or Convenience
phillips allows mis-alignment with the screwdriver and fastener without stripping, but you can gather more torque from a slotted head.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
I prefer slotted or Frearson to Philips.
Provided you use a properly sized slotted driver, you can generate a lot of torque. I was able to remove all 16 of the 4 1/2" bronze slotted screws holding the centerboard trunk in my 1966 GP14 once I cleaned the slots well.
Frearson is a cross shaped head that looks similar to Philips, but is much better. The flutes of Philips drivers are tapered in thickness, and designed to "cam" out with high torques. This is partially why it's so easy to wear out and ruin a Philips screw driver, and to mung up the head of your fastener. Frearson bits have non-tapered flutes, and they don't cam out at all. Of course, you need to have a Frearson bit around...
Oh, the cool thing about Philips or Frearson is that they are self-aligning across the X and Y axis, whereas slotted is not. This can be where you get into trouble with slotted fasteners... Much easier to shoot fasteners in using a mechanical means like a screw gun with Philips or Frearson...
If you strip a phillips you have a lot of work on your hands... if you strip a flat-head, you can always back it out.
I've started using square or star heads... I don't strip them as often.
Robertson is king. We Canadians understand that.
I had to look that up, I did not know a square-head was called a Robertson. :thumbup:
Just to drive my son crazy...I'm going to casually toss that out next time I'm in the shop...
"Hey bud, can you pass me the Robertson bit?":rolleyes:
Likes: Jalepeno
Aug 1, 2011
3,972
What size? 0-4 with a #2 being the most common. (go big or go home)
Bosman
Oct 24, 2010
346
Solina 27 Wabamun, Alberta
Pozi drive, but I doubt these are available on this side of the pond. The power of the square drive with the good looks of phillips. Super easy to work with. But if choosing between slotted and phillips, I go with the phillips.
Aug 9, 2006
99
Oday 34 La Salle, Mi
Ditto on the POZI drive and yes you can get drivers here in the USA. I got mine from Sears
I had a heck of a time on my Nauticat 33 until I found out the screws were POZI drive
Cheers
Pat
NC 33 " DEBRA LYNN"
CYQK
Sep 11, 2009
605
Yeah the slotted screws dominate most all the fast in my boat
Luv my milwaukee though
Nov 8, 2010
11,386
Pozi was designed as an 'improvement' of the Phillips to facilitate volume production, both automated and manual. 95% of the benefits of the design lie there; in the speed and ease of alignment of the tool facing. If care is taken with a phillips, pozi is not really any better.
Nov 6, 2006
10,212
Phillips or Reed-Prince .. I like to see the little "X's" all lined up ... look at a Hinckley and you'll see what I mean; if the heads are visible, they are all aligned. They come from builder that way.. I took some time to do the fasteners on my toe rails and T-tracks that way .. my Hunter certainly did not come that way!
Nov 9, 2012
2,500
Pozi is used on Alpine ski bindings - I'm shootin' screws into skis all the time. Having seen Bosman's pic above, I can totally see how the bit looks to be an evolution of Philips. However, to me, the fastener head still looks like it can cam out and get ganked up easily. That's why I like Frearson... Never knew Frearson existed until I bought a bunch of silicon bronze screws from Jamestown Distributors to work on the GP14...
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
What? No Arthur Spooner head screw lovers? It's shaped like an "A". Must be a King of Queens fan to enjoy that one. ;)
Jul 7, 2004
8,534
Hunter 30T Cheney, KS
Lots of options presented. probably need a poll next :)
I prefer Phillips. Common drivers are always slipping out of the slots
kito
Sep 13, 2012
2,011
I know the slotted heads are a pain to line up when using a power drill or when you can't see well or when your hands are not steady............
Likes: Brian S
