Slotted or Phillips ?
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I am surprised that the dovetail slot and the offset cruciform is missing. We use the offset cruciform a lot here at work.
pateco
Aug 12, 2014
2,207
Had to look those up
Offset Cruciform
Dovetail Slot
Likes: kloudie1
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
Don't use Slot or Phillips. I've replaced all of them with Robertson or Allen key hex socket. Do you remember how they had such a hard time replacing components on the Hubbel upgrade mission a few years ago? Some idiot assembled the original using Phillips machine screws.
Ward H
Nov 7, 2011
3,814
I read a while back, I think it was a suggestion by Main Sail, to use Allen Head machine screws, either socket head or round head. You can easily cut the short end the allen head wrench shorter, then tape the long end down using Gorilla tape when putting screws through the deck. Then from the inside you can install the nuts and use a power driver to tighten them without a helper. Worked well for me.
