Hello,
On my 1984 Macgregor 25 the genoa is torn and in need of repair and I'm not sure how to remove it. It is on a roller furler and pictures are attached. Above the spool on the furler is an aluminum tube which the sail is slipped over and with the fore-stay running up inside this tube. In the diagram from the Macgregor manual the upper forestay attachment is like the diagram except for there is no block for a jib halyard.
What is the easiest way for me to remove the genoa from the furler and put a jib on the furler
while I do repairs.
Thank you for reading.
