On the B 311 that I bought this fall, it appears that the lazy jacks have been tied way to short. As a result they are holding the boom up higher above the deck, which results in a fuller mainsail shape. I think I need to adjust these so the mainsail can be flattened more.
The lazy jacks are tied onto round battens in the top edge of each side of the sail cover, there is no form of adjustment built into this system other than loosening and retying each lazy jack to the battens. This is not like any lazy jack system that I have read about in the past. The owners manual loosely describes this method of attachment but does not specify what kind of knot should be used. On my boat it appear to be nothing more than several wraps around the batten followed up with a couple of half hitches. This appears to be pulling the battens forward causing the forward end of the battens to wear through the sail cover batten pocket and protrude out of the forward end of the batten pockets. I assume this forward end should be sewn shut to keep the batten in place. The lazy jack knot wraps also appear able to slip forward along the round batten. This has torn the forward edge of a couple of the batten pocket cutouts at the lazy jack attachment points. Which is why I'm thinking that a rolling hitch would be better as they tend to grip much better.
Has anyone else experienced these problems and have any advice? I will try to remember to take a photograph of this configuration next time I get out to the boat.
