Fuel Filter Exchange on Yanmar 4JH4TX2
Sep 5, 2009
136
Hunter 45 CC Marina del Rey
Please help! I have a hunter 45CC with a Yanmar 4JH4TX2 engine. The fuel filter on the engine has a cover which I cannot remove - the manual is not specific about that.
Thanks so much! V
Do you have any pictures? There may not be a whole lot of 45CC or 4JH4TX2 skippers here, but others may be able to help.
Dec 25, 2000
6,060
The fuel filter on our 4JH2-TE (1991) is a spin on canister filter like the oil filter. Our current one is ten micron that was installed by the PO. I have a spare spin on that is six micron. We also have a ten micron Racor cartridge filter between the fuel tank and the engine.
199
Hunter 45 CC Alamitos Bay, Long Beach
Thanks so much! V
Viktor,
I have the same boat, 2006 Hunter 45 CC, and the same Yanmar Engine, 4JH4TX2, I believe that the bottom portion of the filter spins off and inside is the fuel filter element, that you replace The top portion of the filter housing is the manual fuel pump for priming, (filling) the filter prior to starting the engine.
Jeff
SV Sooooo Lucky
Hunter 45 CC
Feb 16, 2012
199
Thanks so much! V
Viktor,
Now that I think about it, the bottom portion of this filter assembly screws off, like a typical filter cartridge would. The replacement fuel filter element just screws back on, typical to changing the engine oil filter. The "button" on the top of the assembly is used to manually pump fuel into the new filter/cartridge prior to starting the engine.
Jeff
