Loose Nut
Oct 4, 2008
147
Hunter 36 Mulberry Cove Marina
I'll have to get back to you with the exact measurements. Roughly it is the size of your thumb nail and probably 6 threads.
Ted
Jan 26, 2005
1,280
To me it looks like an adjusting nut of some sort because of the very distinct marking on the top. The curved line with a circle at the end seems to indicate that if you turn the nut counter-clockwise you will be minimizing the adjustment and if you turn it clockwise you will maximize IT. The question now is, what is IT? Since it is painted grey, it's most likely a Yanmar part since that's the color they paint their engines. I was going to say it looks like an adjusting nut for throttle or gear shift linkage but I think you may have noticed other issues before you found the nut. Sorry, no other guess here.
Likes: Rasselas36
Beneteau 323 Annapolis MD
Maybe a lock-nut for when you adjust the angle of an electronic device- maybe at the helm. Or a radio that is panel-mounted but never had the brackets installed behing the panel? Do you have a hatch with a brace that would use that locknut on?
147
Thanks but there aren't any electronic devices near the engine compartment.
Aug 3, 2012
2,542
I would think the picture of the Sperm on the nut would give you some idea of its use! :)
Mar 20, 2012
3,983
its off of a tool.... I cant remember the tool or if it was a power tool or a hand tool, or where it was when I saw it, but I remember the coarse knurling and the little design on it....
check your tool box for whats missing an adjuster/tensioning nut....
Likes: Rasselas36
Oct 4, 2008
147
Thanks. I am starting to feel better. I'll go through my tools and ask my diesel mechanic if he recognizes it. Have a great day.
Oct 4, 2008
147
YOU are amazing. GOD Bless you! I know exactly where I put my feeler gauge and when I get home I am going to see if it is missing this nut. Odds are it is. I wish you a prosperous and healthy NEW YEAR my friend.
Nov 6, 2006
10,247
WOW.. Mr. Walker.. You win the prize on this one.. I knew I'd seen a nut like that before but couldn't place it!.. My feeler gauge set has the same tension nut on it!..
Likes: Rasselas36
Mar 20, 2012
3,983
yep... off a tool. it makes one wonder how a person can recognize an object for what it is, yet not remember where it exactly fits into the picture.... senility or altzheimers maybe... scary thoughts:wahwah:
Ted
Jan 26, 2005
1,280
I'm LMAO! I can't believe you solved this mystery. twalker, that has to get you at least one "LIKE"
Likes: Rasselas36
