I'm essentially rebuilding my rudder - the upper white plastic gaskets were broken and worn, which caused my Al tiller to become damaged. The red rubber friction gaskets were also worn, causing the rudder to inch up, even when fully tightened. I have a new tiller, upper plastic gaskets, tiller stop and red rubber friction gaskets.
I'm wondering what adhesive to use for the red rubber friction gaskets?
The old gaskets were done differently. One was poorly afixed with what looks like clear marine grade silicone. That one came right off and was torn, probably because it broke loose and was torn when the rudder was raised after coming off the water. The other looks like it was glued on with 3M 5200. I had to use a metal spackle knife and hammer to get the gasket off. Almost every bit of the adhesive is still on the aluminum - I'll have to sand it off. That gasket was most certainly affixed...
I was thinking maybe 3M 4200? It's similar to the 5200, just not as hard when it dries. I've also heard of some using a 2 part epoxy called PC11. I know many have replaced these red gaskets on their 23.5 / 26 / 260 rudders. Please let me know what you used.
Thanks in advance.
Thanks in advance.
