Mast head spinnaker halyard block
Nov 16, 2012
1,055
My rigger was up the mast today, putting LED bulbs in, and he said that the spinnaker block at the mast head was not a good design. It's the same as the turning blocks at the base of the mast, which don't deal well with the variable lead angle. He's got some ideas of what to replace it with, but I thought I'd ask what other C310 users have up there, if they use it.
Jun 27, 2013
42
Beneteau First 285 McFadden Cove Marina, Kaw Lake, OK
I'm just about to replace my masthead sheave. Good luck, I'll let you know if we learn anything from the job.
Feb 20, 2011
8,062
So you're saying that they're not articulating?
I would definitely want a fully articulating (swivelling) block up there.
Jun 1, 2004
8,360
Swivel block with shackle.
Also, it helps to have a spinnaker bail or crane attached to masthead fitting that gets the block farther out front of the headstay. If you have a "snuffer" for your asym, the sleeve gets bunched up at the top and can interfere with things sometimes.
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
I have the same crane as Valcour. I added a Garhauer block that swivels.
Aug 1, 2011
3,972
Paul, did you make that fixture? I need to move mine out about 6" to get clearance for the furler, and was thinking about crafting something like yours.
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
The first crane was made and installed by rigger.
I made the second crane and my grandson installed it.
paulj
:hook2:
