Thinking about replacing my Jabsco manual toilet with a Raritan. What sort of issues will I be facing? e.g. removal of old unit, mounting bolt differences, hose connections, etc.
Raritan makes a bunch of toilets, both manual and electric...which one are you yearning for?Thinking about replacing my Jabsco manual toilet with a Raritan. What sort of issues will I be facing? e.g. removal of old unit, mounting bolt differences, hose connections, etc.
Ok...I finally get an answer to my question...you want to stay with manual. That would be a PH II or a PHC, which is the compact version. Both are available as complete toilets or "conversions," which allow you to keep your existing bowl, seat and lid....converting your manual Jabsco to a manual Raritan. Check them out here: Raritan LBA Upgrade for almost any toilet.Chuck:
Did you mean you converted to an electric Raritan? Our Jabsco is manual and we want to stay manual. I could not find a conversion kit to take me from a manual Jabsco to a manual Raritan.
Yup...and sho' nuff, there it is, right on schedule.Peggie, I hear ya, but the next question usually is: How do I get to the nuts on the bottom of the bolts???![]()
All marine toilets are mounted using lag bolts...there are no nute, so no need for any access to the underside of anything...just back the bolts out.
@Scott Wauquiez, sorry for the delay in responding, I've been out of the country. I did make the conversion, and there were a few hiccups, but they were very minor. Let me see if I can remember the issues.SFS - did you ever take on the LBA project? When I looked at the mounting diagram, it looked like the bolt holes were offset 45 degrees from those on my current Jabsco bowl, which is why I ask.
The diagram on the LBA page (http://shop.sailboatowners.com/prod.php?52006/) - (Diagram: http://shop.sailboatowners.com/emp/images/Bowl_holes.jpg) shows the holes at 12, 3, 6, and 9 O'clock for the LBA, yet the holes for my Jabsco bowl are at 2:30, 4:30, 7:30, and 10:30. Granted, I could rotate the bowl 45 degrees but I think The Admiral would protest.
OK, here's MY hack job!I could get a few couplers and a small amount of intake hose but I don't want it looking like it was hacked in after the fact.
