Hi Catalina 22 Owners,
We have a Catalina 22 (a Jaguar 22 here in the UK) from around 1980 (could be earlier- mid-late 70s) which we enjoyed very much this summer - until the cable for the swing-keel broke.
We continued to enjoy sailing the boat, but it now has to be taken out of the water for the winter, and we have a few concerns.
Several questions:
- In doing research, I was surprised to read stories of boats dropping their keel completely - can this actually happen on a Catalina 22? Is it physically possible?
- If it can happen, how can we check it - there is a large bolt (or ball?) at the front on which it pivots I understand. Is there any way to inspect this or any part of the keel while the boat is in the water?
- I see that there is a small square panel inside the boat around where the front of the keel could be - is this an inspection hatch? It has four screws so that seems likely...
- Even if we do inspect the front of the keel, how would we know if it is safe or not? And what should we look for?
- Then comes the cable, as I mentioned this snapped but appears to not have done any damage, although the keel is now permanently down. We need to take it out of the water and put it on it's yard trailor- it usually sits very low on its yard trailor with the keel in the up position. We are not sure if it was actually resting on the keel before - could that be? Presumably that would not be good... it also had wooden blocks around it, so they could have been taking most of the weight. (we have only owned it for one season so this will be the first time that we take it out of the water)
- So simply asked, as we take it out of the water, how do we manage the fact that the keel is down rather than up?
- And then next question is how do we repair the broken cable once it is out? (it is broken at the keel itself, ie: the cable is all inside the boat.)
Any help with any of the above would be much appreciated!
Stirling
Several questions:
Stirling
