Replace fuel tank
Oct 5, 2010
322
Catalina 30 mkII St. Augustine
Anyone replace their fuel tank? I am interested as to how you secured the new tank to the hull.
Jan 6, 2010
1,519
HV,
Are you matching the existing tank? Making mounting pads for a new tank is pretty simple. Just match where your mounting areas are. You find a material say1" thk., glass it to the hull & glass over it. Use some ss screws with caulk.
If I were you, first I'd call my friend Lenny @ Catalina in largo Florida. They make all kinds of stuff for the C30's. (727) 544-6681
If you do go this route, I would also have them put in an inspection cover on top. Go with a min. of 4" either square or round. This will allow you to clean any sludge without having to pay someone to do it. Catalina have good pricing on remaking orig. parts.
CR
Likes: hvbaker
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
My plywood bed was still in great shape so I just screwed the new tank down with 1" stainless screws and washers.
Got my tank from Catalina Yachts. $450 after shipping and taxes.
Likes: hvbaker
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
My tank was aluminum with tabs that were glassed to the hull. I used a 3" grinder to remove the glass. The tank was a tight fit. Luckily the original manufacturer label and part number was on the tank and ordered through them who were still in business under a different name (RDS). I tried to go through Catalina first but they didn't have the same tank that was installed. I epoxied four G-10 blocks to the hull that were drilled and threaded. I used straps to secure the tank and to the blocks. It is removable for the future.
Oct 5, 2010
322
DJ2210, thanks. I am doing something very similar to you. I got some aluminum and am going to epoxy to the hull and then strap the tank down using screws. I also ordered the tank from RDS and then drove to Perry to pick it up. I got wholesale pricing at $350 because they thought I was a boat yard when I called.
Oct 5, 2010
322
I had to change design, the long skids would not lay flat. I cut them down and have two per side.
