Sounds like a Plan. Bring some dielectric grease and fill the coax connector "F-Fitting" with it before screwing it onto the new antenna. That should slow down the moisture intrusion, and corrosion of this connection.Gotta love this forum!! Great stuff and taking a little from everybody I got my plan. I have Time Warner coming out to hook up the dock with a wireless router that will broadcast to the boat while in the slip. I will be going up the mast later and will be taking a new UFO along with a high gain WIFI antenna and pulling the new wiring using the old coax. No sense trying to patch old electronics. Thanks to all!!
It is a disc shaped omnidirectional antenna. Not as powerful as a directional antenna, but you keep your signal while spinning at anchor.Maybe I'm missing something, but it looks like the antenna is mounted sideway?
This is similar to the capture systems used in Cable TV street level hardline distribution taps and amplifiers. Should work fine. The connection I was speaking of was thou one up the mast connecting to the omni antenna.take a look at the original picture (hopefully I have posted it below). The RF cable has the plastic stripped from the shield and then a captive bar is screwed down over the shield to make the ground. The center conductor goes to screw terminal on the board. Very unconventional method for terminating an RF cable and probably doesn't perform that well plus likely prone to corrosion problems. However.. it looks like not that difficult to just cut the cable back a little and re-do everything using fresh ground and center conductor on the cable. That RF cable connection looks like someone didn't care if it worked for a long time. If nothing else.. that would be an easy thing to try.
FYI, it is not the tiny voltage from an ohm meter that you need to worry about if you probe that circuit, it is electro static discharge (ie, ESD or shock). The cable going up to the antenna will have 12 volt plus the RF signal on it. The meter will screw up the RF performance if you touch that cable but not the slightest damage problem with measuring voltage or resistance.
On the consumer products I have worked on in the past (25 years in that bushiness) we would always test all ports (such as the DC plus RF ports on that board) for ESD in the design phase. This would be a very fast transient pulse with a peak of 8000 volts to simulator ESD so that it had spectrum in the RF range of interest.. Whatever the device had to perform perfectly after the test. Why do this.. customer returns are very expensive and its not at all hard or expensive to make electronics withstand ESD.
Will do. I also use uv rated liquid tape on any exterior or weather proneSounds like a Plan. Bring some dielectric grease and fill the coax connector "F-Fitting" with it before screwing it onto the new antenna. That should slow down the moisture intrusion, and corrosion of this connection.
Just the viewing angle. I was standing on the dock because of the sunMaybe I'm missing something, but it looks like the antenna is mounted sideway?
Agreed, the deformation of the cable will cause signal issues, but only at the higher frequencies used by Satellite or newer digital cable plants. For the signals received off air, this issue should be minimal.Something like the cable shield ground clamp used by that off air antenna that partially crushed the cable would have screwed up the specs we needed to achieve (mainly insertion and return loss). .But.. when the connections are good (like when new), that set up is probably good enough.
I agree,,,who knows how much is degraded and where so that is why I'll get a whole new upgrade. It would be kinda like fixing that 15yr old refrigerator.Yep..
I attached a blowup of the OP's cable (at the circuit board) going to the antenna. The black arrow points to the cable shield. It could just be the picture but the black color of the metal shield mesh doesnt look healthy.. I dont think it looked like that when new - but Im just going from the picture. .
Absolutely not. The 75 ohm characteristic is at the operating frequency. If you put an ohm meter on it you will be dealing with DC resistance.Actually I have never had a tv hooked up to this. This what the PO had set up. So should I be able to see 75 ohm between the center wire and shield on the tv input with 0v?
