Unfreeze bolts
Nov 24, 2014
207
Catalina 310 Staten Island
PB blaster. BTW, an ounce of prevention is worth a pound of cure. I have found that putting Park Tools ASC-1(anti seizing compound, a product manufactured for bicycles and sold in bike shops) on the turnbuckle threads at the beginning of the season will prevent seizing stays. Also twisting the fittings back and forth 1/4 turn at least monthly during the season is helpfull
Dec 28, 2010
462
Catalina 380 san pedro
PB blaster is the best I have used so far. 42 yrs in aviation maintenance. just an opinion. And I second the poster that recommended anti sieze compound. recently removed my exhaust manifold, exhaust flange and exhaust riser after 7 yrs of use and abuse. not one bolt or nut failed to come apart. I found no rust on the studs at all. I use permatex by the way.
RussC
Sep 11, 2015
1,689
Merit 22- Oregon lakes
PB is ok, but try the GM product I posted above next time. I've built many many street rods from the 30s to late 60s, over the past 40+ years, so I've pretty much tried every rust buster ever produced ;) . The GM product beats them all, hands down, and also works well on stainless bolts and aluminum bits. Kroil would be a close second, but it's harder to locate locally for most people, and some have said they think Kroil actually makes the GM stuff for them anyway.
Russ
Dec 28, 2010
462
I have many products in my tool locker that are 'penetrants' I'll have to get a can of that GM product and give it a try thanks.
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
Also, when (if) the chemicals fail heat, as a last resort, is your friend. Propane torch used sparingly.
Likes: RussC
