yan 3jh4e 40 hp diesel, 5 yr old 300 hours, has 2 hot water hoses ff the thermostat block which circulate hot antifreeze-filled hoses through the water in the Isotherm 24 liter hot water heater to heat the w after up when the engine is running. (the heater hoses off the engine block feed into a stainless steel closed loop inside the HW heater.)
the HW heater blew a seam, the water leaked out. the heater hoses are still attached to the engine (and it's a closed system). hoses are rated 220degrees F and 70 PSI.
is there any problem in running the engine (for 20 minutes) to get to the haul out, even though t here's no water in the hot water heater engine hose loop ?
all thoughts and advice welcome .. we haul out this week end and there's not enough time to rip out the old HW heater and replace with new before then...
