I have been researching boat lifts and trying to determine a way to modify an existing power boat lift to accept a Yankee Seahorse 24. From what I have been able to determine and from studying the trailer the boat is currently on, it appears most of the weight of the boat is supported by the stub keel, which is approximately six feet in total length and 12 inches wide at the widest part. My understanding is the bunks on the sides are mainly there to keep the boat from tipping over, according to what I read on the Internet.
My son and I have an existing boat lift that has bunks that are the same length as the existing bunks on the sailboat trailer. It appears all we need to do is to add a support for the stub keel and raise the bunks to the correct height and locate them under the hull at the correct points.
My plan is to laminate twelve 2X4s on edge for the stub keel support. The boards will be glued and screwed together and held in place by angle iron on the sides and both ends. I have measured the distance from the front of the stub keel to the front bunks on the existing trailer and that distance is 18 inches. We plan to use the trailer dimensions for locating bunks and the stub keel support platform on the lift.
I have attached a photo of my modification plan. If anyone has every tried anything like this, I would appreciate any thoughts or concerns. The cost of the modification is approximately $600.00 dollars for all of the materials. My son and I plan to do the work ourselves. Before we start spending the money, I thought it would be a good idea to get any feedback from experienced sailors, who may have used lifts before.
We plan to paint the boat bottom within the next few weeks and modify the trailer as well. We will apply two barrier coats of CM-15. One coat black, one coat light gray, along with a final top coat with a suitable paint to protect the barrier coats from UV.
I appreciate any comments. We have two other lifts that support power boats, but this is our first sailboat and we are learning as we go.
