On page 51 A & B you will see a diagram of the centerboard. I assume you are in a different country. I cannot recall the specific but believe the board is around 110 pounds. It is a fiberglass with construction foam for light weight with a stainless steel frame inside. The first key is weight or you will not get it up if too heavy. Then there needs to be a concentration of structural integrity in the head of the board where it pivits not to mention the precise holes that have to be drilled for the pin and uphaul.
line. If you do not know how to do this, I suggest that you think otherwise and simply order a new centerboard. It can be purchased thru this forum site store.
If you feel that you can build one, I suggest contacting Bob Walker at
BobWalker10@aol.com or call him at 352-529-1104 as he owns Foss Foam Products of Florida which is a division of New Rudders or Newrudders.com. He would know and may share the schematics of that centerboard as he built them for Hunter.
Again I would suggest biting the bullet and purchase one.
