Hey all,
i have a 25' Oday and the plywood bulkhead which the shrouds are attached to has rotted out and the attachment plate pulled away from the plywood ( what was left of it anyway ). I've cut out the entire piece of plywood, since 60% of it was wet and ruined. I still have the portion of it which is next to the hull which is fiberglassed to the hull left to figure out. Anyway, to my question, any ever replace this plywood or similar structural pieces with marine grade polymer plywood? I've searched online and found a couple of manufacturers and it's not clear what the structural specs are for the polymer boards. i.e. are they similar in specs to plywood for a given thickness... The plywood used on my boat is 1/2". I plan to call the 800 number to ask this, but figured i'd throw it out there.
pic of the "through" hole attached.
btw, the cause of the wet plywood, i believe was water leakage from the deck plate following the plate down into the cabin where the plywood is. I'm guessing this happened over several years and since the plywood was poly-ed and painted over time, it didn't get noticed.
Don
Don
