You didn't mention if you were going to be doing a lot of anchoring, so my response is based on assuming you will be cruising your new 35' boat a bit farther afield than you did on your last boat.
I think you are going to need a bit heavier ground tackle for a 35 footer than 30 pounds. Probably more like a 35# pick and about 50' of 3/8 chain, if you don't want all chain.
IMO you really should invest in a powered windlass.
A lot of folks may disagree, but we saw two boats last season that were in serious situations because their manual windlasses just couldn't get the gear up fast enough, in dire circumstances. One nearly hit us several times and just escaped dragging across our anchor chain because they just couldn't get their gear up fast enough. The captain was up on the bow cranking for all he was worth, pulling possibly 3" of chain with each stroke, instead of 60' per minute with a powered windlass. His wife was doing her best to hold the bow to wind, but in 55+ knots of wind, the boat was all over the place.
As for backing down, if you are paying out the chain by hand, that seems a bit of over kill. Falling back on the wind should be more than sufficient to pay it out cleanly, and certainly much easier on your hands. No need to rush things, especially if you are using your body for jobs that are heavy and dangerous.
