I have a Yanmar ignition panel with ignition switch 127412-91250. The ignition switch got kicked while underway, and the plastic fitting that is inside the box, between the main switch body and the panel, was broken. This fitting slides over the threaded barrel that comes through the panel, and has a small square-cut tab on it that fits into a small square cut slot in the panel. Once in place, the rain-cover slides over the outside threads, with the outside plastic nut then going on to hold the whole thing in place.
If anybody has that part, or even a defunct ignition switch that still has that part with it, please let me know if you would sell it. By the way, there is no part number for the inside or outside plastic fittings, only a part number for the whole ignition switch.
My other reason for posting here is that I'm having no luck with the two online places who have the ignition switch for sale, nor am I having luck with a "local" Yanmar dealer.
Many thanks.
Many thanks.
