Diesel mechanic is stumped:
Perkins Prima M60
Well maintained
4th trip of season. Running from Perth amboy to Annapolis. At cape May engine died suddenly just prior to switching from starboard to port tank. The port tank is about 30 gallons. Had been topped off in the fall by the yard. Filters on engine changed prior to trip. At time to change tanks, it was noted that the fuel in racor looked like strawberry quik. Despite using additive, new o rings on fill, filtering fuel and last yr emptying tank and cleaning it.. Fuel was drained from racor, filters changed, fuel flushed from lines and injector input lines. After bleeding, noted that fuel flow did seem poor while cranking. Would not start.
In cape may, mechanic repeats what I did and it starts for 1 min then stalls.
Then lift pump not working well. Eclectic fuel pump placed. Bucket with fuel as source. Fuel line to lift pump bursts.
Fuel line and return replaced.
Lift pump fine now. Purging air from injectors by cranking. Air purges. Won't start. Flow not so great from injector feeds.
What else could it be but a damaged high pressure pump?
Perkins Prima M60
Well maintained
