- Oct 22, 2014
- 24,926
Perhaps it does not want to be tested again... What did you do to it last time?I am trying to remove it again for testing but it will not come out.
It is often the simple things that hold you up...
- Are all of the bolts and nuts that hold it in place released?
- Does the pump have a specific rotational position that is needed on the cam to allow the pump gear shaft to be removed?
- When the unit was installed the last time, did anything bind as it was being installed?
- Are there any hoses/pipes connected that are restricting removal?
