Cockpit rigging
May 3, 2015
3
Oday O'day 22 MH Terrace BC, Canada
I'd like to know what the original cockpit rigging configuration was for an early 70's O'Day 22 was, anybody have pictures?
Apex
Jun 19, 2013
1,219
C&C 30 Elk Rapids
sorry no helpful info, but instead of looking for OEM, take the opportunity to make it your own. rigging is a personal preference, so enjoy! I like the jam cleats, had them on my C25, quick and easy to set and release.
Oct 19, 2009
97
oday 22 Lake New Melones
My setup is not original, but works well for me.
The sheet leads through a car on a track that adjusts for the jib or genoa, to another block ahead of the winch, to a clam cleat behind.
In the photo there is a second car on the aft end of the track. I was experimenting with different lead angles to the winch and did not adopt any changes.
21
Oday 22 Great Kills Harbor, Staten Island, NY
For photos, you can Google ODay 22, and should find pictures of the stern. There is no stern rail or traveler. The back stay has a topping lift attached for the boom, and the main sheet is attached with a triangular plate to the back stay. The lifelines begin about the front half of the cockpit on an eye on the combings, and are rigged forward through 2 stantions to the bow rail. There are small winches for the jib sail on each side, as well as pairs of cleats behind the winches, and over the transom.
Sep 19, 2013
21
I think that the earlier ODay 22s may have had a slightly different main sheet arrangement. As stated, there are lots of photos if you google.
