I posted on the Macgregor forum questions about a furler head sail size here http://forums.macgregor.sailboatowners.com/showthread.php?p=1205225#post1205225
But what I’m wondering from trailer sailors in general is if you have a boat in the 22 to 26 foot range (my boat is a 1990 26S) and have a furler, how to you pin the forestay during mast setup and get good tension.
I know you can do this with a Johnson lever but I know a lot of people do this just fine without the lever.
When I had a furler in the past, I had a little pulley setup that I would hook around the fuler base and use this to pull things in place so I could pin the forestay. This "sort of" worked..
